Error using F1 in RS2008
Klaus
if i open help an select an contens it generates error and can't use RS.
See files
Best regards klaus
Best Regards
Klaus Soenderhegn
www.cadalysator.dk
Klaus Soenderhegn
www.cadalysator.dk
Hi Klaus,
The error seems to be caused by wxvault.dll which is part of a software called "Embassy Trust Suite". If you don't use that software I recommend you uninstall it. If you do, please check if there's an updated version available.
http://mikedimmick.blogspot.com/2007/12/calling-out-embassy- trust-suite.html
regards,
Johannes
Johannes Weiman2008-5-26 10:27:1Johannes Weiman
Hi Johannes.
Thanks it help
thanks for quick response
best regards klaus
Best Regards
Klaus Soenderhegn
www.cadalysator.dk0 -
