ACM5.13.02 ABBControllerTest, it does not on VPL.
jesus
Hello.I followed the steps of the installation of ACM 5.13.02 as indicated in the user guide v2.1.
The hardware and software requirements of my computer are correct:
?_? Microsoft Visual Studio 2008 SP1.
?_? Microsoft Robotics Developer Studio 2008 R3.
?_? The ACM 5.13.02 Package.During the execution of setup.cmd no errors appears.
During the execution of build.cmd are several warnings and errors related to the ABBController Test service .Once I completed all the steps of the installation of ACM, ABBController Test service, is not on the list of services in VPL. However services are installed:
?_? ABB Controller.
?_? ABB Joint Stream.
?_? Simulated ABB 6 Arm.I'm doing development with MRDS and need to use the ABBController Test service .
jesus2012-01-01 23:59:38
Hello Jesus,
Wish you a very Happy New Year 2012!
The ABBController Test service is not a
part of the standard Package for Download and is for internal use only. The ABBController Test service is obsolete and was only supported upto the earlier versions of RobotStudio (Ver. 5.11.) This could be the result of multiple warnings, you are experiencing while executing the
Build.cmd.Best regards,
Srikumar0 -
Hello again.
OK Srikumar. I've seen that in building of services, does not ABBController.Test.
I have tried the tutorials ACM 5.13.02. AVL connects whit RS to a station offline.
Do the examples in the folder TutorialTest really work with a real controller?.
Is there any application in ACM 5.13.02 that connects a real controller?
Thanks and best regards.
Jesus.
