Welcome to the new RobotWare forum!
In this forum we invite you to write your questions regarding RobotWare functionality and options.
Topics from the "General Discussion" fourm regarding RobotWare have been moved to this new forum.
The main purpose of the forum is to let users share their experiences and questions with each other, but ABB will also try to clarify and help when neccessary and possible. However, for urgent support matters, please contact your local ABB representative.
Fredrik Pahlm
Moderator
ABB Robotics R&D
  • Dear sir,
    I have a IRB5400-02 robinstall files in library,but no kxt files attached, so I can not make  a system file and startup file for robot, where can I get the kxt files to continue the making It .
    A.abaee
  • my screenshot
  • Hi, I am working to make a 3x IRB 2600ID + IRBP-R arc welding station and when I try to make the operation system from lay-out, the system can't find a mediapool structure for 3 robots and a table.
    The result is a OS with the three robot and no IRBP-R.
    Where can I get this special configuration option to add to my mediapool library?
    Thank's.
    Dr. Robot
  • you can install robotware version 5.14
  • hi
         Good evening i need s4c controller robotware boot disk(3.x) files.
