RobotStudio Add-In and .Net Framework 4.0
I would like to use a library in my robotstudio addin which needs .Net Framework 4.
So I decided to changed the Target Framework in Visual Studio to .Net Framework 4.
After I changed the framework the addin does not even appear in Robotstudio.
Is it possible to use .Net Framework 4 in Robstudio addins?
I use Robotstudio 5.13.02.
Steve
SteveO2012-01-13 15:39:22
  • In RS 5.13.xx you can not use .Net Framework 4, but in RS 5.14 you can.
    ABB Robotics
