Post-Pro Delmia V5/V6 IRB1400/2400
Hi everybody,
I a new user of this forum
I custom an ABB post-processor for Delmia V5/V6
I'v got two robot IRB1400 and IRB2400
I've a problem of syntax into the program
Can you help me please ?
Julien
Here is an example of program
error message controler : 40705(syntax error)
error main error syntax
expected 'trap' found "-"
line 5 column 15
  VERSION:1
  LANGUAGE:ENGLISH
MODULE IRB2400-JZ1
  ViaPoint1:=[[1480.15,-6.276,1526.357],[0.497619,-0.502369,0.497641,-0.502348],[0,-2,1,0],[9E+09,9E+09,9E+09,9E+09,9E+09,9E09]];
  ViaPoint2:=[[1429.881,-571.484,1526.742],[0.208171,-0.212251,0.67248,-0.677779],[-1,-3,2,0],[9E+09,9E+09,9E+09,9E+09,9E+09,9E09]];
  ViaPoint3:=[[1260.973,-687.297,1627.984],[0.208171,-0.212251,0.672481,-0.677779],[-1,-3,2,0],[9E+09,9E+09,9E+09,9E+09,9E+09,9E09]];
  ViaPoint4:=[[1291.407,-731.429,1628.275],[0.208171,-0.212251,0.672481,-0.677779],[-1,-3,2,0],[9E+09,9E+09,9E+09,9E+09,9E+09,9E09]];
  ViaPoint5:=[[1289.521,-736.526,1053.619],[0.208171,-0.212251,0.672481,-0.677779],[-1,-4,3,0],[9E+09,9E+09,9E+09,9E+09,9E+09,9E09]];
  ViaPoint6:=[[886.152,-1014.669,1057.408],[0.208172,-0.21225,0.672481,-0.677778],[-1,-4,3,0],[9E+09,9E+09,9E+09,9E+09,9E+09,9E09]];
  ViaPoint7:=[[1214.444,-784.8,1584.717],[0.53199,0.170927,0.68416,-0.468717],[-1,-3,7,0],[9E+09,9E+09,9E+09,9E+09,9E+09,9E09]];
  Prehenseur IRB2400_4_Tool1:=[TRUE,[[58.622,-6.275,225.211],[0.703756,0,0,-0.710442]],[0,[0,0,0],[1,0,0,0],0,0,0]];
PROC IRB2400-JZ1()
  MoveJ ViaPoint1,v1000,z50,Prehenseur IRB2400_4_Tool1;
  MoveJ ViaPoint2,vmax,z50,Prehenseur IRB2400_4_Tool1;
  MoveJ ViaPoint3,v1000,z1,Prehenseur IRB2400_4_Tool1;
  SetDO 1,on;
  MoveL ViaPoint4,v1000,z50,Prehenseur IRB2400_4_Tool1;
  MoveJ ViaPoint5,v1000,z50,Prehenseur IRB2400_4_Tool1;
  MoveJ ViaPoint6,v10,z50,Prehenseur IRB2400_4_Tool1;
  SetDO 1,off;
  MoveL ViaPoint7,vmax,z50,Prehenseur IRB2400_4_Tool1;
ENDMODULE
  • Hi,
    Try replacing the hyphen (-) with a underscore (_) in your module and procedure names.
    Regards
    Graeme
  • Hi
    RobotStudio tells you all the errors when you check the program:
    Not allowed in a name: -
    Same module and routine name is not allowed.
    Data have to be defined.
    Name with space is not allowed.
    Output name need to be more then only a 1.
    VERSION:1
    LANGUAGE:ENGLISH
    MODULE IRB2400_JZ1
    CONST robtarget ViaPoint1:=[[1480.15,-6.276,1526.357],[0.497619,-0.502369,0.497641,-0.502348],[0,-2,1,0],[9E+09,9E+09,9E+09,9E+09,9E+09,9E09]];
    CONST robtarget ViaPoint2:=[[1429.881,-571.484,1526.742],[0.208171,-0.212251,0.67248,-0.677779],[-1,-3,2,0],[9E+09,9E+09,9E+09,9E+09,9E+09,9E09]];
    CONST robtarget ViaPoint3:=[[1260.973,-687.297,1627.984],[0.208171,-0.212251,0.672481,-0.677779],[-1,-3,2,0],[9E+09,9E+09,9E+09,9E+09,9E+09,9E09]];
    CONST robtarget ViaPoint4:=[[1291.407,-731.429,1628.275],[0.208171,-0.212251,0.672481,-0.677779],[-1,-3,2,0],[9E+09,9E+09,9E+09,9E+09,9E+09,9E09]];
    CONST robtarget ViaPoint5:=[[1289.521,-736.526,1053.619],[0.208171,-0.212251,0.672481,-0.677779],[-1,-4,3,0],[9E+09,9E+09,9E+09,9E+09,9E+09,9E09]];
    CONST robtarget ViaPoint6:=[[886.152,-1014.669,1057.408],[0.208172,-0.21225,0.672481,-0.677778],[-1,-4,3,0],[9E+09,9E+09,9E+09,9E+09,9E+09,9E09]];
    CONST robtarget ViaPoint7:=[[1214.444,-784.8,1584.717],[0.53199,0.170927,0.68416,-0.468717],[-1,-3,7,0],[9E+09,9E+09,9E+09,9E+09,9E+09,9E09]];
    PERS tooldata tIRB2400_4_Tool1:=[TRUE,[[58.622,-6.275,225.211],[0.703756,0,0,-0.710442]],[0,[0,0,0],[1,0,0,0],0,0,0]];
    PROC rIRB2400_JZ1() MoveJ ViaPoint1,v1000,z50,tIRB2400_4_Tool1;
      MoveJ ViaPoint2,vmax,z50,tIRB2400_4_Tool1;
      MoveJ ViaPoint3,v1000,z1,tIRB2400_4_Tool1;
      ! you need to have an output called something like: do1 -> SetDO do1,1;
      MoveL ViaPoint4,v1000,z50,tIRB2400_4_Tool1;
      MoveJ ViaPoint5,v1000,z50,tIRB2400_4_Tool1;
      MoveJ ViaPoint6,v10,z50,tIRB2400_4_Tool1;
      ! you need to have an output called something like: do1 -> SetDO do1,0;
      MoveL ViaPoint7,vmax,z50,tIRB2400_4_Tool1;
    Best regards
    Marcel
  • Hi,
    Thanks for your comments
    regards
    Julien
  • Hi,
    here is the good code !
    Modification list :
    - necessity the good I/0 adress "DO10_1"
    - Define the center gravity, the inertie of the tool and define a short name like tool1
    - add PROC main() behind the mov list
    - add "ENDMODULE" at the end
    Thanks for your help!
    regards
      VERSION:1
      LANGUAGE:ENGLISH
    MODULE jul7
      PERS robtarget ViaPoint1:=[[1480.15,-6.276,1526.357],[0.497619,-0.502369,0.497641,-0.502348],[0,-2,1,0],[9E+09,9E+09,9E+09,9E+09,9E+09,9E09]];
      PERS robtarget ViaPoint2:=[[1429.881,-571.484,1526.742],[0.208171,-0.212251,0.67248,-0.677779],[-1,-3,2,0],[9E+09,9E+09,9E+09,9E+09,9E+09,9E09]];
      PERS robtarget ViaPoint3:=[[1260.973,-687.297,1627.984],[0.208171,-0.212251,0.672481,-0.677779],[-1,-3,2,0],[9E+09,9E+09,9E+09,9E+09,9E+09,9E09]];
      PERS robtarget ViaPoint4:=[[1291.407,-731.429,1628.275],[0.208171,-0.212251,0.672481,-0.677779],[-1,-3,2,0],[9E+09,9E+09,9E+09,9E+09,9E+09,9E09]];
      PERS robtarget ViaPoint5:=[[1289.521,-736.526,1053.619],[0.208171,-0.212251,0.672481,-0.677779],[-1,-4,3,0],[9E+09,9E+09,9E+09,9E+09,9E+09,9E09]];
      PERS robtarget ViaPoint6:=[[886.152,-1014.669,1057.408],[0.208172,-0.21225,0.672481,-0.677778],[-1,-4,3,0],[9E+09,9E+09,9E+09,9E+09,9E+09,9E09]];
      PERS robtarget ViaPoint7:=[[1214.444,-784.8,1584.717],[0.53199,0.170927,0.68416,-0.468717],[-1,-3,7,0],[9E+09,9E+09,9E+09,9E+09,9E+09,9E09]];
      PERS tooldata tool1:=[TRUE,[[58.622,-6.275,225.211],[0.703756,0,0,-0.710442]],[2.066,[2.91,-7.017,-42.395],[1,0,0,0],0.008,0.009,0.005]];
    PROC main()
      MoveJ ViaPoint1,v1000,z50,tool1;
      MoveJ ViaPoint2,vmax,z50,tool1;
      MoveJ ViaPoint3,v1000,z1,tool1;
      SetDO DO10_1,1;
      MoveL ViaPoint4,v1000,z50,tool1;
      MoveJ ViaPoint5,v1000,z50,tool1;
      MoveJ ViaPoint6,v10,z50,tool1;
      SetDO DO10_1,0;
      MoveL ViaPoint7,vmax,z50,tool1;
    ENDMODULE
