Starting program after programload [WebWare SDK]
Hi, I would like to know how one should do to start the program from webware after a programchange. I manage to start it with the parameter "main" in the s4start method but not with a empty string "".
We don't want to start the program from main in case someone has moved the robot with the joystick.
It works with:
Helper1.S4Start(0,"main",-1,1,3,ref intResultID)
but not with:
Helper1.S4Start(0,"",-1,1,3,ref intResultID)
This is just a problem after a S4ProgramLoad() call.
Do one have to init the Helper control or something after a programload(change of program)?
Regards
/Sven
As I read the documentation, using an empty string parameter in S4Start means to resume from the current location, i.e. program point.
If you have just loaded the program, then I am guessing that the "current location" is considered empty or undefined before you have executed the program. As a result, I would expect the call to fail.
I would assume that passing in a <Procedure Name> should work, however.
Russell Drown0 -
What I really wanted to achive was, when start button is pressed: 1.After a programload -start from "main".
otherwise start from ""(current location).
So, I simply implemented that... FIXED.
If you load a *.prg (S4ProgramLoad) the program pointer will be lost so you can't start from previous program pointer anymore only from main.If you load a *.mod (S4ModuleLoad) and the programpointer isn't in that module you will be able to start from where you where.
Per Svensson
Company Specialist
ABB Automation Technology Products0
- 359 IRC5
- 77 OmniCore
- 851 RAPID Programming
- 30 AppStudio
