Target approximations
Hi guys,
If I use an approximation z50 to a target, and I test it at Manual Mode will the robot have the same behaviour when I test the same target on Automatic Mode?
Hope you understand what I mean :P
Best regards
Tiago Gaspar
Tiago Gaspar
  • That's the beauty with ABB robots path will be the same no matter what speed you are running at
    Per Svensson
    Consat Engineering
  • Thanks =)
    Tiago Gaspar
