Moving multiple objects
VictorL
Is it possible to move multiple object using line mover without attaching them all to each other?
Yes it is,The easiest way is to use a queue that you move with the lienar mover, then add the objects that should be moved into the queue. You will find a tutorial about this on the community. Another way is to attach a component group to the linear mover, and then add the objects that should be moved into that group with help of "SetParent".Best regards,
Dear Andres S,
I leave you a private message regarding this topic. I hope I can answer.
Best regards!0
- 365 IRC5
- 84 OmniCore
