Default action on importing robot target to path
When importing robot targets to one path in Robotstudio, first time you are asked about what kind of action to take (MoveL, MoveJ, ArcLEnd, ArcLMove, etc). I was unlucky enough to choose ArcLEnd by mistake and now I can not change it any more in Modify Instruction !!! In addition ALL new robot tagets I import to that path are imported as ArcLEnd !!!!!!!! Can anyone please tell me how to fix it ? It's a very irritating bug
Thx in advance,
Shahaboid
Shahab
Sky is the limit ...
Shahab
Hi,If you can not change it with the modify instruction option you may have to sync to the VC and change it in the offline editor (use find and replace to make it quicker).I think the import uses the settings at the bottom of the screen (see screen shot), if yours is set to ArcLEnd then change it to MoveJ or MoveL.
RegardsGraeme0 -
Thx. It worked :-)--
Shahab
Sky is the limit ...0
