PC SDK and x64 Apps
Has anyone experienced PC SDK on an x64 app?
We have a multi camera/multi robots app having to deal with several 5Mpix cameras which will feel too tigh on an x86 machine.
First attempt to compile PC SDK apps under x64 is not successfull.
Help...Confused
  • Hi,
    i had the same problem in my old post but the answer to me and confirm by experience that you can compile your project with PC SDK explicit only for x86 machine if you want that it correctly run under x64 operative system or the PC SDK don't work in x64.
    i hope that this information help you.
    bye Ema
    ECapitanio2012-02-01 16:56:15
  • Thanks for answer.
    I will stick with x86 until it comes.
