Need help with RS-addin development on C#
Hello RS-Community
I would like to retrieve the object properties (position, name ...) of a graphic object when clicked with the mouse pointer on it. Did it with the "GraphicPicker Class"attempts. But do not come on.
Philipp.Gastel2012-02-08 21:27:31
I found out there, this is the solution
handler:
GraphicPicker.GraphicPick + = newABB.Robotics.RobotStudio.Stations.Forms.GraphicPickEventHandler(OnSelection);
argument:
static void OnSelection (object sender, GraphicPickEventArgs e)
Logger.AddMessage (new LogMessage (e.PickedObject.Name + " " + Convert.ToString (e.PickedPosition)));
Philipp.Gastel2012-02-08 21:27:030
