Help me pls, PC SDK can't write Rapid
plux3001
Hi,everyone.
I create an object representing the rapid data,i want to write data reg1 or data other in rapid
help me pls.
Thank you for Example
Hi,everyone.I using C# .0 -
Do you know what the "reg1" mean?It's located in the "User Data Types", and you can find the "User Data Types" by the FlexPendant.you also can refer to the "Working with RAPID data" which is in the PC-SDK Application manual.0
