Help me pls, PC SDK can't write Rapid
Hi,everyone.
I create an object representing the rapid data,i want to write data  reg1 or data other in rapid
help me pls.
Thank you for Example Clap
  • Hi,everyone.
    I using C# .
  • Do you know what the "reg1" mean?
    It's located in the "User Data Types", and you can find the "User Data Types" by the FlexPendant.
    you also can refer to the "Working with RAPID data" which is in the PC-SDK Application manual.
