Error trying to build system from backup
I'm trying to build a system from a backup but I get this error -
Can anyone help?
  • The system you try to create have an "additional option" which use the media pool displayed on the message window. You must have this media pool in your PCs media pool library (C:Program Files (x86)ABB Industrial ITRobotics ITMediaPool) to be able to create the system. If you have access to the real robot can you use "Go Offline" in the Online-tab, that function will copy this media pool to your PC.
    ABB Robotics
  • Thanks Anders, that's done the trick.
