3dConnexion SpaceMouse
aryder
I'm having trouble with my 3dConnexion SpaceMousePlus3. I'm using RS 5.14.01. Motion of the SpaceMouse works fine in all respects apart from the "roll" function which persistently rotates the geometry in the opposite direction to that desired. Within the 3dConnexion control panel I have a custom configuration for RS. In the "Advanced Settings" tab I have the option to deselect and / or reverse the motion direction(s) with a check box. All of these check boxes work (pan/zoom/tilt & spin) apart from the "roll" option. Selecting the "reverse" check box has no effect. Similarly deselecting the motion has no effect.
Has anyone else encountered this issue? I'll raise it with 3d Connexion. It may be down to the age of my SpaceMouse.
BR,
Alasdair
Hi,The "Roll" function is not used in RobotStudio. The only direction I have reversed in my setup is "Zoom".Best regards,
I know I had issues with a simpler 3Dconnexion mouse simular to your description and later upgraded to a spacepilot pro (older monochrome version) and now the engineer took that one and I'm using the older Space Explorer, both works great with RSBest regards
Alexander Källberg0
- 359 IRC5
- 77 OmniCore
- 851 RAPID Programming
- 30 AppStudio
