Import keyID file
Quintrix
Hello,<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
Since a while I `m a quickteach 5.4 user.
I have a question about how to get the same robot in quickteache like the one you have on the field.
If you have a V4.0 controller, its quite simple. You just have to enter the key string that you find on the back of the baseware cd.
I'm having a V2.1 on the field, and the only way is to read a key id from a file.
Where can I find that file? I thought I could find it on the installation disks, but my research did not give any results.
Thx in advance.
Q
I don't know where you can find the key id file, but you can select "Create" instead of "Create from Key" and manually select the robotmodel and baseware options.
ABB Robotics0
