Is Reachable
Is there
a way to ask the robot after it get to one position, if it possible to move to another position
in Cartesian coordinates (RobotTarget) without moving the robot ?
And
if the robot answer "Yes" to get the joint values
of the new position ?
<?: prefix = o ns = "urn:schemas-microsoft-com:office:office" />Avi Cohen
thanks Mika for the example ?As
I understand the function like "CalcJointT" is part of RobotWare <?: prefix = o ns = "urn:schemas-microsoft-com:office:office" />Do
you know if it possible to access them from PC SDK ?regards
Avi
The PC SDK does not have such features in itself.Well, you could always tell it to do something and then let it shift data back. With the reservation that I don't know what you want to accomplish, but I've seen applications where they use RobotStudio and a Virtual Controller for that. As in sending positions to the VC, the VC tries to execute them and run the results back. Then the PC SDK stores the result which is then run as a whole simulation before trying it out at the real robot.John
Developer Center0 -
Thanks john,<?: prefix = o ns = "urn:schemas-microsoft-com:office:office" />
I have 2 questions regarding it.
1. Can I perform something like CalcJointT from PC Sdk?
2. I have a set of targets in Cartesian coordinates, I need to ask for each target the
robot if he can reach to this position (without moving it), if robot answer "YES",
convert the target from Cartesian to joint, if robot answer
"NO", change the configuration and ask again, until I get
"YES" for all the points, than I need to build a module with a
procedure that run between these points, load this module to robot, and run it.
What I need to know how can I ask the robot if he can reach to a target without
moving it?
