Bug in RS 5.14.02
Hello, I have a small complain regarding RobotStudio software. If you want to manually change position of robot target, after choosing "set position" option you end up in local position window, cursor in "value for X coordinate" window. When you switch to world position, zero from local X coordinate window sometimes get erased, you got exclamation sign, and when you try to apply new values to world coordinates, RS freezes, and closes, there's nothing that you can do. And usually you lose all work you just did. Could creators of RS fix this bug please. Thanks in advance.
Thanks for the information. Please create a support log as described in http://forums.robotstudio.com/forum_posts.asp?TID=2164 and send to me at henrik.berlin@se.abb.com or upload to the forum.We would very much appreciate your help. That would be very valueable to us and help us to pinpoint and fix the problem.Henrik Berlin
HiI had that problem also , but it resolved after I upgraded the computer Vista to Windows 7BRPetri0 -
Have issues with x value diapearing aswell when setting positions of items, running windows 7Best regards
Alexander Källberg0 -
Upgrade did go ok, but I still have problem that x value disppear when setting positions of items, but at least now RS does not crash.0 -
What version of RS are you running?
RS 5.14.02.010 -
Please upgrade to 5.14.03. We have tried to improve the error handling to prevent this problem from occuring. The download page is available from http://www.abb.com/roboticssoftware
ABB0
- 359 IRC5
- 77 OmniCore
- 851 RAPID Programming
- 30 AppStudio
