Use Offs and RelTool in Station
radim
is it possible use the instruction Offs and RelTool in MoveL in Station (HOME->Paths&Targets)part. Because it is importing from VC (virtual controler) but I can not use in (HOME-> Paths&Targets). Robot doesn't want to execute Jump to MoveInstruction.
Your observation is correct. RobotStudio does unfortunately not fully support these functions. This limitation is described in the Release Notes. However, the RAPID program will execute correctly.
ABB0
