IRB660
i m facing problem in using IRB660 when i m inserting this robot in robot studio one msg popup i.e."the library of type IRB640 for the mechanical unit 'ROB_1'in the robot system'IRB660_180kg-3.15m_3'is not defined.you must manually search for the library." so please replay if any one knows.
  • Which version of RobotStudio are you using? Please describe the exact sequence of steps you take.
    ABB
