The ABB IRB 120 DH parameters
I want to simulate ABB IRB 120 robotic arm with the matlab software. I got the drawing from webpage. However I need to create a Denavit-Hartenberg table for the forward kinematic calculations. Could anyone help me to create this table because I am so confused about it.
Thank you.
  • Hi,
    In this lecture of mine, you will find the D-H parameters (using the original D-H method, not the one proposed by Craig) of the IRB 120: https://cours.etsmtl.ca/gpa546/Notes/L6L7.pdf
    In addition, I suggest that you install the following free program of ours: http://youtu.be/VnFIpp1W0Vk
    Ilian
    A%TS, Montreal, Canada
  • Thank you Ilian. Its quite helpful.
  • The are really helpful. explain it all
  • Thanks very much for the notes. Although the ones I found are in french, they are still very useful but are there English versions by any chance?
  • Hi
    It is possible to repost a link with the pdf file? I seems that the old one is not working anymore. Tkank you in advance!
