Location of legacy robotware?
Is there anywhere you can download older versions of Robotware? I'm specifically after 5.14.1032 so I can bring a real life system back into RobotStudio (Create from Backup), but the installed version I have is later.
Thanks in advance!
If you can't get the full version, then anywhere I can get a 5.14.1032 Media Pool for the "Track" option?0
