Robotware 5.07 requires RAB 5.07??
Does Robotware 5.07 require RAB 5.07? If so, when is it released?
Does RAB 5.07 require VS .NET 2005 or is it recommended?
Jan-Jaap
You must recompile your application with RAB 5.07 in order to use it with RW 5.07. I do not know what the planned release date is, can anybody else answer that question?
VS 2005 is supported with 5.07, but there isn't any compelling reason that I know of why most users would want to migrate yet, i.e. Design View support is not yet available.
Russell Drown0 -
Does RAB 5.07 support Robotware 5.06 (and older)? Or is it possible to have both RAB 5.06 as well as 5.07 installed?
Regards,
Jan-Jaap0 -
I have not tried a 5.07 FPSDK app against RW 5.06, but I doubt that it would work because 5.07 is built against Compact Framework 2.0 and a 5.06 system would not have CF 2.0.
Your 5.06 application will most likely work without changes (read the release notes to see what changes there are), other than being re-compiled against 5.07 RAB.
Russell Drown0
- 350 IRC5
- 848 RAPID Programming
- 21 AppStudio
