Where is the "FlexPendant Command Server"?
fransis
Hi,everyone
who can tell me where is the "FlexPendant Command Server".
I don't find it.
I don't find it.
Hi Fransis,This is not a part of the published SDKs. So it's not something we should discuss on a public forum.
As such you need to go through your local ABB support channel instead and explain why you would need to use that.
John
Developer Center0 -
Application manual -FlexPendant SDK-7.2 Debug output-FlexPendant Command Server (P184)
that have something about check memory resource command,
I want to know whether "MyApp.Dispose()" is OK.
Do you have other way?
Hi fransis,No there is no other way if you want to check the real memory consumption on the actual FlexPendant for memory leaks.With that said, if you read further down in that chapter you can see that it refers to how to call it. If you don't know how to set up the command console then I would again recommnend that you contact your local ABB support channel to get help with that.My hands are a bit tied when it comes to this.John
Developer Center0 -
thanks,
at this time, with equation of time,
off work .
go home .
