How to run buttons in auto mode??
jerry-licao
in ScreenMaker
I made a screen which contained some buttons , I downloaded it to flexpendent,But the
buttons only can be click in manual mode,how to run it in automatic mode? Thanks
Hello Jerry,I think you must be using RunRoutine Button control. By default this control would work only in Manual Mode. If the button is required to run in Auto then there is a property in the control called "AllowInAuto". Set this to TRUE and redeploy your application on FlexPendant.ThanksAbhishek1
AbhishekThanks , I was successful with your method,Thanks very much!Happy new year!0
HiI have the same problem but i have set allowinAuto to true - Any suggestions?0 -
rosa,were you able to solve your problems with "AllowInAuto" ? Hopefully everything worked out ok for you. Please update us if you haven't gotten your problem solved.0
Thanks for this useful trick.
I will try this night in home.
Thanks and cheers!!!
Manuel Perez Lopez0 -
Now I've found this very effective trick. It really works! Thanks everyone...
WHY www.hamptonbay-lighting.net?
because the best ceiling lighting is only found at www.hamptonbay-lighting.net0
- 348 IRC5
- 845 RAPID Programming
- 21 AppStudio
