About Flexpendant SDK(No fact stands without Pic)
I know the Flexpendant SDK can operate
RapidData with Creat ,Edit and Delete.I want to go a step further. To operate
Instruction with Add,Edit and Delete.In this app, I achieve to Add a Instruction
and Edit Instruction. Using the same method, It?_Ts also can Delete Instruction.But , It?_Ts not graceful.
1.
I can?_Tt find a method to read
the content of a instruction in memory directly, include PP line and the Cursor
line.2.
Although I achieve it on a circuitous
route, But I find a new problem. I have not a suitable method to analyse the
Content. The method about ?__.FillFromString()?__ ?_o.ToString()?__ ?_o.ToStructure()?__ will
user-defined.I can?_Tt use a graceful way to know whether this instruction
is what I need.3.
I use the PP event to check and
Edit the Instruction, but I don?_Tt find the Cursor event of double Chick to edit
it as the Flexpendant System do it formerly.I can?_Tt find the way to Use the event of Flexpendant
System.4.
Take one step back, we don?_Tt use
the event. Can I add a item to the Program Editor/ Edit Page , what is the
Cursor stoped in the movie.I want my App don?_Tt show on the start Bar.
(it?_Ts so simple)And I can call it in the Program
Editor/Edit page.(It?_Ts seem possible)After , I can analyse the instruction of
the cursor line, to show diffent form. (read the memory?)Return the value to the instruction.(write
the memory?)Just as the app is a part of the System.
fransis2012-05-17 05:42:120
