TriggL with zones
Gizmo
I have a TriggL instruction with a TriggInt, but the trap routine only runs if I use a fine point. In the rapid reference the example has a zone configured. I've tried setting the TriggInt to fire at various distances from the target position, inlcuding 0, but it only ever works if I use a fine point.
CONNECT OpenClampsInt WITH OpenClampsTrap;
TRIGGINT OpenClampsTrigg,0,OpenClampsInt;
!Move up to the flyby and open the clamps once clear of the product
TriggL pNextPosition,DepartSpeed,OpenClampsTrigg,fine,Gripper;
IDELETE OpenClampsInt;
Any ideas what I'm doing wrong?
HiI think the reason is that when using zone, the IDelete instruction is executed before trap is fired. Try to execute without IDelete or execute it later in the program.-Osku0
HiI always execute a IDelete before I do a CONNECT in that way you always know that the connect will work and don't have to care about that PP is running ahead.Per Svensson
Consat Engineering0 -
You should be able to put the IDELETE just before the CONNECT.IDELETE OpenClampsInt;CONNECT OpenClampsInt WITH OpenClampsTrap;
TriggL pNextPosition,DepartSpeed,OpenClampsTrigg,fine,Gripper;Then you should be able to change the zone to something larger.Thomas H. Johnston
PACs Application Engineer0 -
Thanks, so obvious when you say it like that!0 -
[QUOTE=Gizmo]
Thanks, so obvious when you say it like that![/QUOTE]
lol, ahahahaha
- 304 PowerPacs
- 354 IRC5
- 850 RAPID Programming
- 26 AppStudio
