seeking help
I want to creat a station from quick system,but there always an unknown error.
what should I do?
Have but few friends, though many acquaintances.
  • I have reinstalled the soft,but the problem still exists. imageimage
  • Have you tried to create a system from layout?
    ABB Robotics
  • first,thank you for your help.
    I have tried it ,but failed with an unknown error,too.
    I reinstalled it using English in the end ??Onow it works well.
  • Jorge
    Jorge ✭✭
    Try to make a system with only with robot, and no more options. Of course you can choose your language.
    Then try to make the station, if not works, you have a wrong configuration in the manipulador secction of your system. If not, try to add some options.
    Also, if you want, you can copy here the configuration of your system, and I can try it in my RS.
    /Jorge
    Jorge Turiel
