seeking help
huihai
I want to creat a station from quick system,but there always an unknown error.
what should I do?
Have but few friends, though many acquaintances.
I have reinstalled the soft,but the problem still exists.Have but few friends, though many acquaintances.0
Have you tried to create a system from layout?Best regards,
first,thank you for your help.I have tried it ,but failed with an unknown error,too.I reinstalled it using English in the end ??Onow it works well.Have but few friends, though many acquaintances.0
Try to make a system with only with robot, and no more options. Of course you can choose your language.
Then try to make the station, if not works, you have a wrong configuration in the manipulador secction of your system. If not, try to add some options.
Also, if you want, you can copy here the configuration of your system, and I can try it in my RS.
/Jorge
Jorge Turiel0
- 359 IRC5
- 77 OmniCore
- 851 RAPID Programming
- 30 AppStudio
