"Duty factor warning" versus "Joint load
Dear All
   Hi, after using ABB Robot for 4 years, it's a first time I got
Alarm 50263 (Duty factor warning).
"The duty factor for the gearbox of joint rob1_1 of robot ROB_1 is too high.
Continued running without adjustment may cause damage to motor and gearbox.
Contact your local ABB service support center."
Action : Reduce the speed or increase the wait time.
In almost of all the cases, I ussually get Alarm 50055 (Joint load too high).
My question :
1. What is the differences between "Duty factor warning" and Joint
load too high?
  I see that they have the same remedy : reducing the speed.
  Is it right that "Duty factor warning" is a special case of "Joint
load too high"?
2. Actually the robot's cycle time is close to the minimum limit ( I
must catch up the target of speed).
  Is there anyone know the solution to solve this problem beside reducing the
speed? May be there is a parameter that I can set by software?
Thanks and regards
  • Jorge
    Jorge ✭✭
    Duty Factor, is error that raises the robot when, after evaluate the last 30 minutes of produccion (moves, speed, loads, acceleration, etc), thinks that a gearbox is working outside of the specification, and they life will reduce.
    You can reduce the problem, if you change the following parameter:
    MOTION_SYSTEM:
          -name "system_1" -min_temp_ambient_cabinet 5 -max_temp_ambient_cabinet 45
          -min_temp_ambient_robot 5 -max_temp_ambient_robot 45
    Change 45 to 40.
    /Jorge
    Jorge Turiel
  • Dear Mr Jorge
            Thank you very much for sharring your experience. It's very very helpful.
    Regard
  • Jorge, por qué decidiste reducir la temperatura?
  • dhyan said:
    Dear All
    My question :
    load too high?
    load too high"?
    Thanks and regards
    How do you solve 50055 alarm
  • innebandy
    innebandy ✭✭
    edited April 2021
    To Amine108:
    Regarding Error 50055, you need to follow the instructions in the troubleshooting manual as listed below.
    Description: Actual torque on joint arg too high. Might be caused by incorrect load data, too high acceleration, high external process forces, low temperature or hardware error.
    Recommended actions: • Check load data. • Reduce acceleration or speed. • Check hardware.
    When it comes to H/W error, Motor power cable issues are most common.
