RS 5.14.03 bug in System Builder
Here is my annoying bug of late.
New Station (140) with controller works fine
Select Offline tab
Shutdown virtual controller in the menu (rightclick shutdown)
NOW ->
Open the system builder
pick the system you are working on
->a couple of steps forward
Add Multitasking
Finish Angry  I keep gettting a Media Pool error - the changes are actually listed in the summary screen, but it just wont work!
  • Klaus
    Klaus ✭✭
    This error is also in RS.5.14.02.
    I had 2 make a new system insted off add multitasking to the existing system that i had.
    Best Regards
    Klaus Soenderhegn
    www.cadalysator.dk
  • I ended up doing this as well Smile
  • You may need to close and restart RS before using System Builder to modify the system. Remember to I-start to enable the new options. Note that all your data will be lost. You should perform a controller backup before I-starting.
    ABB
