Bug in RS 5.14.02
Hello, I have a small complain regarding RobotStudio software. If you want to manually change position of robot target, after choosing "set position" option you end up in local position window, cursor in "value for X coordinate" window. When you switch to world position, zero from local X coordinate window sometimes get erased, you got exclamation sign, and when you try to apply new values to world coordinates, RS freezes, and closes, there's nothing that you can do. And usually you lose all work you just did. Could creators of RS fix this bug please. Thanks in advance.
