Path Offset (612-1) problem
radekck
I am using student version of RobotStudio 5.13 .
I've got a problem with implementing the Path Offset from the instruction 3HAC 18152-1 Revision: E example.
I've written it like this:
[QUOTE]
PROC main()
start_pos;
sciezka_klej;
PROC start_pos()
ActUnit STN1;
MoveJ Target_1,v1000,z5,GlueGunWObj:=zbiornik_up;
VAR intnum int_no1;
VAR corrdescr id;
VAR pos sens_val;
PROC sciezka_klej()
ConfL OFF;
CorrCon id;
CONNECT int_no1 WITH UpdateCorr;
ITimerSingle, 0.2, int_no1;
MoveL Target_11,v100,z10,GlueGunWObj:=zbiornik_upCorr;
CorrDiscon id;
IDelete int_no1;
MoveC Target_21,Target_31,v1000,z0,GlueGunWObj:=zbiornik_up;
MoveL Target_41,v100,z100,GlueGunWObj:=zbiornik_up;
MoveC Target_51,Target_61,v1000,z0,GlueGunWObj:=zbiornik_up;
MoveL Target_71,v100,z100,GlueGunWObj:=zbiornik_up;
MoveC Target_81,Target_91,v1000,z0,GlueGunWObj:=zbiornik_up;
MoveL Target_101,v100,z100,GlueGunWObj:=zbiornik_up;
MoveC Target_111,Target_121,v1000,z0,GlueGunWObj:=zbiornik_up;
MoveL Target_131,v100,z100,GlueGunWObj:=zbiornik_up;
TRAP UpdateCorr
ReadSensor sens_val.x, sens_val.y, sens_val.z;
CorrWrite id, sens_val;
IDelete int_no1;
ENDTRAP
[/QUOTE]
And a error appears:
I would also like to ask, if it is possible to use this function with Path Recovery and Independent Axes on one positioner.
I will appreciate your help.
Radek
Moved to RobotWare
you have to do the declaration in the right way like below.
Module xyzVAR intnum int_no1;VAR corrdescr id;VAR pos sens_val;PROC main()start_pos;sciezka_klej;ENDPROCPROC start_pos()ActUnit STN1;MoveJ Target_1,v1000,z5,GlueGunWObj:=zbiornik_up;ENDPROCPROC sciezka_klej()ConfL OFF;CorrCon id;CONNECT int_no1 WITH UpdateCorr;ITimerSingle, 0.2, int_no1;MoveL Target_11,v100,z10,GlueGunWObj:=zbiornik_upCorr;CorrDiscon id;IDelete int_no1;MoveC Target_21,Target_31,v1000,z0,GlueGunWObj:=zbiornik_up;MoveL Target_41,v100,z100,GlueGunWObj:=zbiornik_up;MoveC Target_51,Target_61,v1000,z0,GlueGunWObj:=zbiornik_up;MoveL Target_71,v100,z100,GlueGunWObj:=zbiornik_up;MoveC Target_81,Target_91,v1000,z0,GlueGunWObj:=zbiornik_up;MoveL Target_101,v100,z100,GlueGunWObj:=zbiornik_up;MoveC Target_111,Target_121,v1000,z0,GlueGunWObj:=zbiornik_up;MoveL Target_131,v100,z100,GlueGunWObj:=zbiornik_up;ENDPROCTRAP UpdateCorrReadSensor sens_val.x, sens_val.y, sens_val.z;CorrWrite id, sens_val;IDelete int_no1;CONNECT int_no1 WITH UpdateCorr;ITimerSingle, 0.2, int_no1;ENDTRAP
ENDMODUL
Thanks, it helped with mentioned error, but now it's something about the ReadSensor procedure.[Quote]/klejenie/RAPID/T_ROB1/modul_klej(79,2): Error 130 : Reference error : Reference to unknown procedure ReadSensor[/quote]Radek0
- 858 RAPID Programming
