How to change the work's center of gravity?
I created a workpiece and found it had wrong center of gravity.So,how can I change it?I'm using RS5.14.THX
Hi,I have some trouble understanding what you mean with workpiece.If it's a tool you can simply change the tooldata by selecting the tool under "Paths & Targets" and right click to "Modify Tooldata".If the workpiece (payload) is something other than a tool I suggest you read the article about loaddata in the RAPID Reference Manual (RAPID Reference Manual -> Data types -> loaddata)0 -
hi @jupiter103, can you please explain what do you actually mean by "workpiece"? Then it will be easier to help you out.
hi all,the
"workpiece" means models just like cube,sphere and so on.I`m sorry,my English is poor.0
