Problem loading eio.cfg
I have a eio.cfg which loads with a File Inspecting Error.
According to the Config Edit User's Guide "If a parameter file is created on an S4 controller or using ConfigEdit, you should never see this dialog. If you do, the parameter file is corrupt.". The eio.cfg file is from an unaltered backup file from a robot that works just fine!
Any tips? I choose my robot in the robot browser based on the information from BACKINFO.txt, do I need additional add-ins or what might be wrong?
From BACKINFO.txt
>>PRODUCTS_ID:
3HAC2700-2/40 System Pack 3.2
TP Language
Irb 6400
IO Plus
Profibus
Advanced Functions
Multitasking
RAP Communication
IO Plus
LoadId and ColDetect
>>ROBOT_TYPE:
6400/2.8-200
From BACKINFO.txt
>>PRODUCTS_ID:
TP Language
Irb 6400
IO Plus
Profibus
Advanced Functions
Multitasking
RAP Communication
IO Plus
>>ROBOT_TYPE:
6400/2.8-200
Is it such a n00b question or is it just to hard? I would have expected some kind of response by now...0
If you send me the backup I will have a look at it and see if I can find why you get the error.Per Svensson
Company Specialist
ABB Automation Technology Products0
