My RobotStudio becomes Crazy
Jorge
Hello, in my RS 5.14.02 I made a path, I put the targets as I want. Then I try "move along the path", and the robots makes the two points ok, the the 3A? goes to the order side of the stations and says that a axis it's out of range.
If I use "View the robot at target" the robot are showed at the right position, because 3A? target is next to the second one.
Then I sync my station to the Virtual Controler, I goes to simulation select the path, runs the simulation and the robots does the correct path. Also if I do the same from the Virtual FlexPendant, the robot does the correct path.
Of course The configuration of the points are ok. I use MoveL in the path
Any idea?
Thanks in advance
/Jorge
Any idea?
Thanks in advance
/Jorge
Jorge Turiel
We need to take a look at your station, please contact your local ABB Robotics Service representative that can forward it to our tech support, see www.abb.com/contacts.
ABB0
