Smart Component Move to View point
sturner
Im using a graphical switch to move to a view point which appears to only work with 0 seconds.
As soon as the value is bigger than Zero it does not move.
Anyone else get this to work with a time?
Are you using the Event Manager or a Smart Component?
Smart Component.0
You have to have a simulation running in order to use time !!!However... If you click the graphical smart component viewpoint switch, BEFORE you start the simualtion, then the screen seems to oscillate between viewponts which makes you kind of dizzy !Also seems to move beyond the viewpoints sometimes.0
OK... if I exclude the VC from within the simulation setup and run from FP then it will react fine for my needs0
- 359 IRC5
- 77 OmniCore
- 851 RAPID Programming
- 30 AppStudio
