RobotStudio 3.0 help - Search problems
Hi Everyone,
It has recently come to my attention that some people have problems image with the search function in the Help for RobotStudio 3.0, so I did some checking. image
It turned out that the compilation of the help files that is in the release doesn't work on some systems. image
To remedy this our documentation guy imageTobiasimage made a new compilation of the helpfile:
RobotStudio_3.0_helpfiles.zip
image Unzip and place it in:
C:Program FilesABB RoboticsHelp
or wherever you have your installation.
It should take care of the problem. If you have the problem and it remains after you have replaced the files, post here with your OS version and service pack.
Note image that this is only valid for the RobotStudio 3.0 build 2135 release.
Best regards
John image
