spot welding
candy
If I want to do some spot welding work,be I must use the
.I have only installed the robtstudio 5.13,and there is so many questions for me.For example,the definition of the gun tool, teach spot point for robot?_??_?.I am confused,and do I get prompted?0
I suggest you start by reading the RobotWare Application manual for spot welding. The next step would be to load the RAPID template for the spot instructions into RobotStudio, they come with the installation.
I finally get your answer,who did not civic-minded,recklessly post in the forum.Thank you Henrik.
?,"??""?s,?~_?+.??"??<?_?%^?_-?"_a_,?_??_-?"_?s,?>,?.3?+.?r1??_??,??Z?-c?oY??_?_`?~??r???O??+?^`???3?rc?,"?.^?_1?,????_" aria-label="?,"??""?s,?~_?+.??"??<?_?%^?_-?"_a_,?_??_-?"_?s,?>,?.3?+.?r1??_??,??Z?-c?oY??_?_`?~??r???O??+?^`???3?rc?,"?.^?_1?,????_">Alpha0
