Pack simulation
alias
I have BIG problem.
Few days ago, I've format my computer, but I've forgot to Pack my simulation. Now I can't run simulation. Is there any solution for this problem.
By the way, what means Program has to be started from beginning?
I would be very thankful if someone can help me.
This is simulation for my master thesis.
If you have lost the controller system, you need to recreate a similar system using "System Builder". When you load the station, RS will ask you to point the controller system folder as it cannot find it, then you should point out the new one. Keep the current position of your robot when asked about it, then update the controller baseframe using "System Configuration". Sync you program to the VC. Unless you have made changes in RAPID that were not synced to the station, you should be done.
As for the error message, you need to provide some more context for me to understand.
Thank you very much for answer. This solved my problem.Thanks again
< ="application/x-dap-" id="DAPPlugin" style="visibility: collapse">0
