BIG PROBLEM: Can not open station!!!
kuv-vokl
Hello
today i have bit problem !
I can not open the station that i have saved yesterday.
"Unknown Error: Open"
Error message:
RobotStudio .NET exception: Object reference not set to an instance of an object.
Base exception: NullReferenceException
at ABB.Robotics.RobotStudio.Stations.RsPathProcedure.get_ModuleName()
at ABB.Robotics.RobotStudio.Stations.RsTask.GetDeclarationUrl(IDeclaration declaration)
at ABB.Robotics.RobotStudio.Stations.RsTask.AddToDeclarationsCache(IDeclaration declaration)
at ABB.Robotics.RobotStudio.Stations.RsTask.AfterLoad(PimDocument doc)
at RobotStudio.API.Persistence.PimDocument.LoadXml(Stream xmlStream, String expectedDocType, Int64 pimStreamSize, Nullable`1 requiredGuid)
at RobotStudio.API.Persistence.PimDocument.InternalLoad(String fileName, String docType, Boolean readOnly, Nullable`1 requiredGuid)
at RobotStudio.API.Persistence.PimDocument.Load(String fileName, String docType, Boolean readOnly, Boolean allowExisting, Nullable`1 requiredGuid, ProgressNotification progressDelegate, Double progressStart, Double progressEnd)
at ABB.Robotics.RobotStudio.Stations.Station.Load(String fileName, Boolean asReadOnly, ProgressNotification progressDelegate, FileNotFoundNotification fileNotFoundDelegate, Boolean loadGeometry)
at ABBInternal.FileCommands.FileCommandServices.OpenStation(String fileName, Boolean loadGeometry)
at ABBInternal.FileCommands.OpenStationCommandHandler.OpenStationCommandHandler_ExecuteCommand(Object sender, ExecuteCommandEventArgs e)
at ABB.Robotics.RobotStudio.Environment.CommandBarButton.RaiseExecuteCommand(ExecuteCommandReason reason)
Please help
Regards
Klaus Vogel
Klaus Vogel
Kühne+Vogel Sondermaschinen GmbH
Hi,Do you run the latest version of RobotStudio (5.14.03.01)?If not:
http://www.abb.com/roboticssoftware -> Downloads0 -
Hello,yes, i have.
RobotStudio 5.14.03
Version 5.14.4771.3070
Please help, my whole work from many days is gone
Klaus VogelKlaus Vogel
Kühne+Vogel Sondermaschinen GmbH0
