RobotStudio Trial version ?
shahabfm
I was wondering what's the point of a trial version while there is absolutely NOTHING you can do with it. You can not even Save your station !!! If the idea of giving out a trial version is to let other try and see how it works, then Saving, rotating, building a path and etc SHOULD have been activated for the trial time !!! For me EVERYTHING is disabled because there is no license !!!
Is it just me doing something wrong or this is really the trial version from ABB ???
I was kind of dissapointed with it as well but that is why it is "free". I was still able to evalute whether RobotStudio is right for me or not just by playing with Trial version for bit.
kalkulatorkredytowy2012-09-10 19:19:460 -
Even I too got disappointed with it for trial versions. Can't do anything with trial. Should I buy full version0
I've run the trial version of 5.14.03 and I can do everything i can do in full version
AlexK2012-08-20 08:57:06Best regards
Alexander Källberg0 -
I am not able to do a real evaluation if this is for me since I am not able to play with the full version0
- 367 IRC5
- 858 RAPID Programming
