Timers
TommyT
Are standard VB Timers supported in the SDK?
Tommy Thompson - Propack
Yes they are.
The FlexPendant SDK use either .NET Compact framework 1.1 or 2.0(RW 5.07). So in the documentation for .NET Framework it tells you if the class is supported in .NET Compact Framework also if so you can use that class.
Per Svensson
Company Specialist
ABB Automation Technology Products0
- 367 IRC5
- 858 RAPID Programming
