Configuring Console buttons
Hello all,
Im using a IRB140 Type C and I would like to configure the 4 buttons in the robot console. I know that I can configure each button to run a routine but cant figure out where I do this.
Anyone can give me a tip?
Thanks in advance
  • Hi,
    On the main ABB menu tap control panel then on the new screen about half way down you will see ProgKeys.
    Tap this and you can configure the buttons on the new screen that is displayed.
    Hope this helps
    Graeme
  • Found it!
    Thanks mate Thumbs Up
