fVisualBasic Application I RS
Xin-H
I am learning to use Visual Basic to write some RS applications and I am quite a new bee. I have gone through the course material. but there are only few simple eksamples for eksemple "how to open and close a griper" and " how to make object reappear in the same place after robot have picked it up in the pickup position". is there any one knows where I can find more VB eksemples for RS application?
xin
The only examples that are included are those in the API help documentation. That you can access from RobotStudio Help Menu
Per Svensson
Company Specialist
thanks a lot . I found it is very usefull. have tried to write a little program selv, it works.
xin0 -
Yes it's handy to be able to write small apps that do stuff for you.
What you also could do if you need more examples is to download Johns toolbar (source code supplied).
You can find it in this thread http://www.robotstudio.com/userforum/forum_posts.asp?TID=54& amp;PN=1
Per Svensson
Company Specialist
Thank for the tips.I have tired to open the links for the two Zip files, but I can not open it. help!
xin0 -
We have a problem with upload/download right now and our IT guy is looking at it. Will let you know when it's working again.
Per Svensson
Company Specialist
