set date and time on IRC5
Hi All,
Did anyone found a way to set the date and time of the IRC5 by external equipment?
thanks
  • You should be able to set the date and time from a PC using the C# interfaces found in the PC SDK.
    The PC SDK comes with the RobotStudio distribution.  To use it, the robot controller must have the "PC Interface" option.
      Steve
  • Jep, found it.
    Thxs.
  • hi,
    @Rookie can you tell me the call for setting the time?
    BR
