relative transparency
I set a entity with high transparency(70%), now I kan not snap it. I have check it in the object browser, but I can not find it now. I want to change the transparency back to normal. Any body can help me?image
xin
  • Hi
    To be able pick stuff that you have changed the transparency on there is a settings in menu "ViewSettingsView Settings" and there you have the option to change visibilty picking.
    Per Svensson
    Company Specialist
    ABB Automation Technology Products
