I need help with remote disk!
jesseh
Can any one help with remote mounted disk? I need to run large cnc programs on my robot.
I have an abb 6400 s4c m97 with rap option and ethernet board. I'm willing to pay for any help with this project.
thanks,
HiI think the easiest way is to set up a FTP server and buy an option called Ethernet Services FTP. This way you can define a folder at the server PC which is seen by the robot.You can set up the remote mounted disk in the robot communication parameters (SIO.cfg). There you can define the ip address of the server PC, username and password etc. The parameters are described in S4C User's Guide, do you have an access to that manual?-Osku0
