conveyor tracking without PM3
bmrgud
Hello, I'm trying to establish proper configuration for IRB 140T
which should pickup objects from moving conveyor, I'm wondering is it
possible to do it without PickMaster 3, since I could see that software
option conveyor tracking is available only with PickMaster 3. Thanks in
advance, BR.
You can try setting up a coordinated external axis. You would use "ActUnit" and "EOffsSet" so that the robot can monitor and the external unit and compensate for it.
It makes the program more complex, but it is possible to do the operation without pick master.
There is a separate option and hardware for conveyor tracking outside of PM3 when tracking conveyors that are not controlled by the controller. E.g. when using an encoder to read the conveyor position.The Hardware option provides a conveyor board to which an encoder can be attached. The Software option provides a conveyor object tracking and queuing system where one can wait for the object to pass a synchronization switch and then track the object on the conveyor (WaitWObj instruction, followed by coordinated motion using a conveyor work object.Check the option list again, you should find it.Steve0
- 365 IRC5
- 84 OmniCore
