compute distances
Hello.
Can someone share some code to compute distances in RAPID?
I need to compute the distance from the present robot position to a target - say "jointtargetHome".
Case:
Depending on where the robot is and what tool it is carrying, I need to perform different motions depending on the distance to a target. Something like pseudo:
num DistToTarget(CurrentTool, Target T);
Best regards
  • Hello,
    Why don't you apply following function?
    Distance() - Distance between two points
    Usage: Distance is used to calculate the distance between two points in the space.
    Example:
    VAR num dist;
    CONST pos p1 := [4,0,4];
    CONST pos p2 := [-4,4,4];
    dist := Distance(p1, p2);
    Best Regards,
  • Hello,
    as below:???
    IF CurrentPos(pXX,tGripper,100)=TRUE THEN
    ENDIF
      FUNC bool CurrentPos(
        robtarget ComparePos,
        INOUT tooldata Tool,
        num Accuracy
        INOUT wobjdata Wobj)
        VAR num Counter:=0;
        VAR robtarget ActualPos;
        IF Present(Wobj) THEN
          ActualPos:=CRobT(Tool:=ToolWObj:=Wobj);
        ELSE
          ActualPos:=CRobT(Tool:=ToolWObj:=wobj0);
        ENDIF
        IF ActualPos.trans.x>ComparePos.trans.x-Accuracy AND ActualPos.trans.x<ComparePos.trans.x+Accuracy Counter:=Counter+1;
        IF ActualPos.trans.y>ComparePos.trans.y-Accuracy AND ActualPos.trans.y<ComparePos.trans.y+Accuracy Counter:=Counter+1;
        IF ActualPos.trans.z>ComparePos.trans.z-Accuracy AND ActualPos.trans.z<ComparePos.trans.z+Accuracy Counter:=Counter+1;
        IF ActualPos.rot.q1>ComparePos.rot.q1-0.1 AND ActualPos.rot.q1<ComparePos.rot.q1+0.1 Counter:=Counter+1;
        IF ActualPos.rot.q2>ComparePos.rot.q2-0.1 AND ActualPos.rot.q2<ComparePos.rot.q2+0.1 Counter:=Counter+1;
        IF ActualPos.rot.q3>ComparePos.rot.q3-0.1 AND ActualPos.rot.q3<ComparePos.rot.q3+0.1 Counter:=Counter+1;
        IF ActualPos.rot.q4>ComparePos.rot.q4-0.1 AND ActualPos.rot.q4<ComparePos.rot.q4+0.1 Counter:=Counter+1;
        RETURN Counter=7;
      ENDFUNC
    BR Tony
    ABB Robotics Senior Application Engineer
  • Distance() seems to be  the perfect solution, thank you Smile
